De to Spider-man spil og Ratchet & Clank: Rift Apart har nu fået opdateringen, der klargør VRR.
Spider-Man Remastered Release Notes Update 1.007
New Features
- 120 Hz Display Mode (together with system settings)
-- Reduces input latency
-- Increases frame rate target of Fidelity graphics mode to 40 fps
- Support for VRR via system settings
-- When 120 Hz Display Mode is off, slightly increases dynamic resolution targets
-- When 120 Hz Display Mode is on, the frame rate is unlocked and varies based on gameplay
- Improvements to ray-traced reflection quality at glancing angles in low-dynamic-resolution scenarios
Spider-Man Miles Morales Release Notes Update 1.013
New Features
-- When 120 Hz Display Mode is on, unlocks frame rate to vary based on gameplay
- Improvements to TAA upsample quality
Ratchet & Clank: Rift Apart Release Notes Update 1.003
New Features
- Add 120 Hz Display Mode setting to New Game options, so you can turn it on before starting
- Save files use frame captures for their icons
Changelog er fra deres supportsider:
https://support.insomniac.games/hc/en-u ... ease-Notes
