Den sidste anmeldelse du linker til:
"Middenmoters rarely score well on motion sharpness and the TCL 55DC760 should also leave some points there. There is no motion interpolation or other form of improvement for the movement sharpness available. Fast moving objects therefore have a somewhat blurred edge, and fast camera movements can have a stuttering effect. We also notice that the TV at some 24 fps sources suffer from judder."
(Middenmoter = middelmådig)
Det være sagt: Der er een ting jeg ikke bryder mig om ved Samsung UE55NU8005 (for lige at vende tilbage til den): Det benytter PWM ved blot 240Hz til at styre baggrundsbelysningen:
https://www.rtings.com/tv/reviews/samsung/nu8000
"The TV dims its backlight by using PWM flicker at 240 Hz. This flicker is unfortunately present at all brightness levels but is less severe at high brightness. This flicker makes fast motion look a little more clear, but also introduces unwanted duplications, as visible in the photo in the Response Time box."
Det er vanskeligt at finde et LCD TV, der ikke benytter PWM, så det næstbedste er at finde et, der kører med en høj PWM-frekvens, f.eks. 720Hz.
Så mens UE55NU8005 burde klare sig væsentligt bedre end 55DC760 på bevægelsesfronten er det alligevel ikke helt i mål og scorer lige en tand under den gruppe, der klarer det bedst:
https://www.rtings.com/tv/tests/motion/24p
