21. jun 2008, 21:57
#39768
Jeg sælger min hjemmebif projektor + lærred da jeg alligevel næsten aldrig bruger den. (familieforøgelsen optager mere tid end man tror )
Det er en HitachiPJ TX-100 Illumina projektor med KUN 145 timer på pæren. Der medfølger et 100" lærred.
Kvalitets 20m. component kabel medfølger samt loftmonterings pladen.
Projektoren har ingen pixelfejl eller andre skavanker og kan til sammenligning godt følge med modeller som Panasonic AE700 og Sanyo Z3.
4500,- for det hele.
Our thoughts on the Hitachi TX100...
Hitachi's TX100 bring big cinema styles imagery in to your living room. The TX100 features 1280x720 resolution LCD panels allow you to display high definition material and it's high contrast ratio off 1200:1 gives you unbelievably stunning image quality.
The Hitachi TX100 has a number of innovative features; including motorised iris control giving you the ability to optimise the balance between light output and contrast ratio for a film-like display with deep blacks.
Other than it's optical advancements, the TX100 features a front fan exhaust, giving you option of installing the TX100 close to a wall without fear of overheating.
Hitachi have also been able to reduce the fan noise to just 25dBA when used in whisper mode.
Hitachi PJ TX100 Technical Specifications
Display technology LCD
LCD panel 0.7" TFT x3
Resolution 1280 x 720 WXGA
Brightness 1200 ANSI lumens
Contrast ratio 1200:1
Projection lens Manual zoom / focus
F = 1.75 - 2.41.
Lamp 150W UHB
Display size 30" ~ 300"
Video compatibility NTSC,NTSC 4.43, PAL, PAL60, PAL-M,PAL-N,SECAM
HDTV 750p(720p), 1125i(1080i/1035i)
SDTV 525i(480i), 525p (480p), 625i(575i)
Video inputs 1x S-Video (4 pin mini DIN)
1x Composite Video (RCA)
1x Component video (RCAx3)
1x DVI-D HDCP Compatible)
RGB input 1x 15pin D-sub
Control 1x RS232C (9 pin D-sub)
Noise level 32dB (25dB in Whisper mode)
Dimensions (W x H x D) 340 x 110 x 284mm
Weight 4.4Kg
Supplied Accessories Remote control
Power cable
Instruction manual
Video cable
[img]http://www.kronsells.dk/sale/projector1.jpg[/img]
[img]http://www.kronsells.dk/sale/projector2.jpg[/img]
F = 1.75 - 2.41.
Lamp 150W UHB
Weight 4.4Kg
Power cable
Instruction manual
Video cable
