18. okt 2007, 11:53
#25218
Skærmen er ca. 4-5 mdr. gammel og virker 100% som den skal og er kalibreret.
Alt tilbehør medfølger som fod, DVI-kabel original emballage osv. Der er
fortsat garanti på skærmen.
Specifikationer:
# Diagonal (and viewable size): 24" (61cm)
# Response time: 16ms black to white, 6ms grey to grey
# Brightness: 450 cd/m²
# Contrast ratio: 1000:1
# Native resolution: 1920 x 1200 pixels
# Size (W x D x H): 22" x 7.7" x 23" / 15.3" (559,7mm x 195,0mm x 584,7mm /
387,9mm)
# Weight: 14.31lbs (8.3kg)
# Horizontal and vertical viewing angle: approx. 89°
# Dot pitch: 0.270mm
# Power consumption: 57W normal (without audio and USB), 110W maximum (with
audio and USB), less than 2W when active-off and less than 1W when switched
off.
PS: der er ingen pixelfejl!
Reviews:
http://www.anandtech.com/displays/showdoc.aspx?i=2940
http://www.dvhardware.net/review93_dell_2407wfp.html
HBO: 3.800.-
Befinder sig i 2630 Taastrup....
Hilsen
Awan
Specifikationer:
387,9mm)
off.
Reviews:
HBO: 3.800.-
Hilsen
Awan
