#152849
Mit Panasonic X20 er begyndt at slukke af sig selv og derefter blinke rødt 8 gange.
Er der nogen herinde der ved nogenlunde hvad det indikerer, da en søgning umiddelbart ikke gav svar.
Tak.
Af Snurrerundtlyd
#152852
http://www.highdefjunkies.com/showthread.php?7089
Panasonic Plasmas
Power Light Blinking Chart
All Panasonic Plasmas feature a protection circuit that will force the TV to shut down in case of a problem. The malfunctioning part can be identified by the numbers of blinks of the power light.
<<<<<< WARNING - WARNING - WARNING - WARNING - WARNING >>>>>>
Use the following charts as reference material only. Defective boards should be replaced only by trained professional technicians. Misusing or mishandling can result in serious injury and/or permanent damage to the TV. -Neither HighDefJunkies Forum nor I (BruZZi), can or will be held responsible or liable, under any circumstances, for any damages and/or void of warranty resulting from the use of the information posted on these charts.
Panasonic
Consumer Plasmas
2011 Models :
ST30 / GT30 / VT30
Kode: Vælg alt
   BLINKS                PROBLEM                   CHECK POINT
 1 blink          Panel Info SOS                 * No Info Given *
                   LP1 Start SOS
 3 blinks            P+ 3.3v SOS                 A-Board
 4 blinks              Power SOS                 P Main-Board / P Sub-Board
                                                 P-Board / P2-Board
 5 blinks              P+ 5v SOS                 A-Board
 6 blinks           Driver SOS 1                 SC-Board / A-SC FPC
                SC Energy Recovery Circuit
                     A-SC FPC DET
 7 blinks           Driver SOS 2                 SU-Board / SD-Board
                SU/SD Connector DET
                SU/SD Scan and Logic IC
 8 blinks           Driver SOS 3                 SS-Board / SS2-Board / SS FPC / SS2 FPC
                    SS FPC Detect
                SS Energy Recovery Circuit
 9 blinks      Discharge Control SOS             A-Board
10 blinks      Sub 5V SOS / Sub 3.3v SOS         A-Board / SC-Board / SS-Board / P Main-Board / P Sub-Board
                    Tuner Power SOS
11 blinks                Fan SOS                 A-Board / Fan
12 blinks              Sound SOS                 A-Board / Speaker / Woofer
13 blinks          Emergency SOS                 A-Board
14 blinks             IR LED SOS                 A-Board
BOARDS DESCRIPTION:
 P MAIN Board = Power Supply (VT30 Models) - Non-serviceable. Must be replaced for service.
  P SUB Board = Power Supply (VT30 Models) - Non-serviceable. Must be replaced for service.
      P Board = Power Supply (All Other Models)
     P2 Board = Power Supply (All Other Models)
      A Board = Main AV Input / Processing
      K Board = Remote Receiver / Power LED / C.A.T.S. Sensor
      S Board = Power Switch
      V Board = 3D Eyewear Transmitter
     C1 Board = Data Driver (Lower Right)
     C2 Board = Data Driver (Lower Center)
     C3 Board = Data Driver (Lower Left)
     SC Board = Scan Drive
     SS Board = Sustain Drive
    SS2 Board = Sustain Out (Lower)
     SU Board = Scan Out (Upper) - Non serviceable. Must be replaced for service.
     SD Board = Scan Out (Lower) - Non serviceable. Must be replaced for service.
2010 Models :
X24 / C2 / U2 / S2 / G20 / G25 / VT20 / VT25
Kode: Vælg alt
 2 blinks                15v SOS                 D-Board / P-Board
 3 blinks               3.3v SOS                 D-Board
 4 blinks              Power SOS                 P-Board
 5 blinks                 5v SOS                 D-Board
 6 blinks           Driver SOS 1                 SC-Board / D-SC FPC
                     D-SC FPC DET
                SU/SD Connector DET
                    SS FPC Detect
 9 blinks      Discharge Control SOS             D-Board
10 blinks      Sub 5V SOS / Sub 3.3v SOS         A-Board / SC-Board / SS-Board / P-Board
                Sub 9V SOS / Tuner Power SOS
                MIHO 3.3 SOS / LED 8v SOS
2009 Models :
TC-P54Z1
Kode: Vælg alt
UNDER CONSTRUCTION
2009 Models :
PX14 / PS14 / C1 / U1 / X1 / S1 / G10 / G15 / V10
Kode: Vælg alt
 1 blink         STB 5v SENSE Time Out           A-Board
 2 blinks                15v SOS                 A-Board
 3 blinks               3.3v SOS                 A-Board
 5 blinks                 5v SOS                 A-Board
 6 blinks           Driver SOS 1                 SU-Board / SD-Board / SC-Board / SS-Board
               (SC/SS Energy Recovery Circuit)
 7 blinks           Driver SOS 2                 SU-Board / SD-Board / SC-Board
                (SC Floating Voltage Area)
                     (SS FPC/ DET)
 9 blinks      Communication Error between       A-Board
                  Panel-MPU and SYS-MPU
10 blinks      Sub 5V SOS / Main 3.3v SOS        A-Board
                DTV 9V SOS / Tuner Power SOS
13 blinks       Communication Error              A-Board
                     with IC8001
2008 Models :
PX80U / PZ80U / PZ85U / PZ800U / PZ850U
Kode: Vælg alt
 1 blink           STB 5v SENSE time out         A-Board
               (SC Energy Recovery Circuit)
               (SS Energy Recovery Circuit)
 9 blinks     Communication Error between        A-Board / D-Board
10 blinks      Sub 5v SOS / Main 3.3v SOS        A-Board
                DTV 9v SOS / Tuner Power SOS
11 blinks                Fan SOS                 PB-Board
                 with IC8001 (Pesks PRO)
2007 Models :
PE77U / PX75U / PX77U / PZ77U / PZ700U / PZ750U
Kode: Vælg alt
 1 blink          STB 5v SENSE Time Out          DG-Board
 9 blinks       Panel Config SOS
10 blinks      Sub 5v SOS / Main 3.3v SOS        DG-Board
12 blinks              Sound SOS                  H-Board
13 blinks      Communication Error with          DG-Board
                 IC8001 (Pesks Lite 2)
2006 Models :
PD60U / PX6U / PX60U / PX600U
Kode: Vælg alt
 9 blinks           Panel Status
10 blinks          PA SOS / Tuner SOS            PA-Board / H-Board
11 blinks                Fan SOS                 Fan
12 blinks              Sound SOS                 PA-Board
Boards Decription:
Af PeterD
#152860
Det er igang med at kontakte det ydre rum..... ;;)
Af snowflake
#152863
PeterD skrev:Det er igang med at kontakte det ydre rum..... ;;)
Ja, det var også hvad jeg frygtede, men det ser ud til det bare er SS-boardet, så tak til snurrerundtlyd for linket.
Købt hos Elgiganten, men ringede til Panasonic som gav mig nummeret til ElectronikCenteret.
Af Snurrerundtlyd
#152882
Ja der er ikke meget andet at gøre end at sende det til reperation eller købe et nyt.
Elektronik-Centret er et af Danmarks største centralværksteder inden for forbrugerelektronik.
De har værksted ved både Århus (Viby J) og København (Skovlunde).
Her er deres hjemmeside http://www.elektronik-centret.dk
Elektronik-Centret er i øvrigt ejet af F Group A/S, som også ejer Fona: http://fgroup.dk
