24 mar 2006, 14:04
#4258
Hej allesammen.
Er ny i dette forum, og har brug for jeres experthjælp!!!
Er der nogen der kan hjælpe med "pro´s" and "con´s" til dette lækre LG-plasma???
På forhånd tak
Specs:
Resolution 1024x768p
Brightness [cd/m²] 1500
Contrast ratio 5000:1
Response time Less than 1 micro secund
Pixel pitch (mm) 0,897 x 0,675
Supported signal PAL, Secam, NTSC, HD, VGA-SXGA
Colors (R,G,B) 10Bit (1,07 bil- 1024 shades of each
XD Engine XD Engine 2
DCDi Faroudja DCDi
Progressive Scan Yes
Color Temperature Control Normal, Warm, Cool, User, Automatic
Picture Control Dynamic, Standard, Mild, User,Day,Night
Aspect Ratio Correction Spectacle, Full, Orginal, 4:3, 16:9, 14:9, Zoom
PC in Analog 1 (D-Sub 15pin)
PC in Digital 1 (HDMI with HDCP)
Monitor out 1 (D-Sub 15pin)
Control 1 (RS-232c) 1 (IR Jack)
S-Video 1 (D-Sub 9pin) + RCA audio
Composite RCA 1 (RCA) + RCA audio
Component (Y/Pb/Pr) 1 (480i/480p/576i/576p/720p/1080i) + RCA Audio
Euro Scart 2 (Full scart)
Antenna (Analog tuner) 1
På forhånd tak
Specs:
DCDi Faroudja DCDi
