#35206
lg 226wtq-sf med ghosting og andet i spil
fik en løsning på problemet
her er en guide
1. Power off your monitor with POWER button
- Hold MENU button and keep it pressed while pressing POWER button
2. Press MENU button to enter Service menu
3. Change panel type
- Press SET button until PANEL text is yellow and press (-) two times to change it to LPL22W 4L
- Press MENU button to close the Service menu
- Press POWER button to power off your monitor and remove power cable for a minute and plug it in again
Af doit
#35238
ja det løste problemet med ghost og farveglitter
skærmen virker fint nu
