#369827
LarsCJ skrev: 24 jun 2025, 17:07 TCL NXTvision og Hisense Canvas er så vidt jeg ved de eneste alternativer, hvis det er et TV med en mat skærm beregnet på billedvisning, du er ude efter.
Ja det er lidt hips som haps.
Der skrives
"NXTVISION are extremely similar products, with little to differentiate them. The TCL has slightly better contrast, but in turn, the Hisense is the brighter of the two TVs, especially in SDR content. The Hisense is a bit more accurate in HDR, but its SDR accuracy is abysmal; the TCL, while not very accurate in SDR either, is still much better than the Hisense. Overall, the two TVs are similar enough that you should get the cheapest of the two, although the Hisense TV's SDR brightness advantage is noticeable."
https://www.rtings.com/tv/tools/compare ... 3953/70375
Og en test mellem Samsung og TCL
"The Hisense CanvasTV 2024 and the TCL NXTVISION are extremely similar products, with little to differentiate them. The TCL has slightly better contrast, but in turn, the Hisense is the brighter of the two TVs, especially in SDR content. The Hisense is a bit more accurate in HDR, but its SDR accuracy is abysmal; the TCL, while not very accurate in SDR either, is still much better than the Hisense. Overall, the two TVs are similar enough that you should get the cheapest of the two, although the Hisense TV's SDR brightness advantage is noticeable."
https://www.lydogbillede.dk/test/tv/sam ... -nxtframe/
#369828
Tak for svar.
Det er mest designet i forhold til rammen jeg tænkte på, men det hænger måske sammen med den matte skærm som du beskriver.
Ved du om 2025 modellerne af TCL er kommet ud? Synes Flatpanels linker til dem, men når jeg kommer videre ind på fx Elgiganten, er det 2024 modellen.
#369831
Elgiganten roder vist lidt rundt i det. Søger man på NXTvision (sidste år hed de NXTframe) kommer der nogle skærme frem, som angiveligt er fra 2024 - og de bruger også billederne fra sidste år. Men tjekker man modelbetegnelsen, så er det 2025-skærme.
Der er praktisk taget ingen andre TV på det danske marked end de tre nævnte mærker som har en billedramme-lignende design. Men du kan jo altid få en glarmester/plakatbutik eller lignende til at lave en billedramme til hvilket som helst TV.
