Af darkdevil
#26968
Hvor højt bør mit 42" plasma egentlig sidde. Vi sidder godt 3 m fra tv'et og lige pt sidder det så der er 60 cm fra gulvet til bunden af skærmen (ca. 46 cm til hvor tv'et begynder). Det sidder nærmest så når vi sidder op i sofaen så kigger vi midt på skærmen.. Er det ikke optimal højde, synes jeg at have læst et eller andet sted.
Af Snurrerundtlyd
#26975
An Introductory Guide to Mounting a Flat-panel TV (1)
LCD TV Installation and LCD Mounts
http://www.practical-home-theater-guide ... ounts.html
Mounting: Once you decide on the spot where you plan to hang your LCD TV, it is time to decide on whether you will be making use of an LCD TV floor stand or a wall-type LCD mount. If you opt to hang your LCD HDTV on a wall, then you also need to determine the optimum height at which you will affix your LCD mount.
There are a number of considerations that come into play when setting the screen height. The idea is to come at a level that proves comfortable on your neck. The guideline is that the maximum vertical angle of view i.e. the maximum vertical angle measured at the seated eye height from the front-row center-seat to the topmost part of the screen, should not exceed 35 degrees (more on this in our TV viewing distance article).
Nevertheless, this represents the maximum vertical setting. Ideally, the center of the screen should be at eye level when seated. This is the position that will result in a minimum of eye and neck movement during TV viewing.
Many may consider that aesthetically, this may yield a too low placement for a wall-mounted display. The alternative is to place the LCD mount such that the bottom part of the screen is no higher than eye level when seated, while the top of the display is no higher that eye level when standing. Anything between these limits should always lead to a comfortable viewing experience.
