11 mar 2018, 08:05
#268953
Jeg sælger min forstærker (PT-7000 Preamplifier/Processor/Tuner) og effektforstærker (7/2100 Power Amplifier) af det amerikanske mærke Sherbourn.
Begge er i perfekt stand og kun lidt brugt, dog virker volume knappen på forstærkerens remote ikke 100%.... tror det er en løs forbindelse.
Sherbourn PT-7000 (SSP)
● 7.1 Operation
● Bass Management: Crossovers at 40 Hz to 150 H
● Input Impedance 26 kOhms
● MFR: 10 Hz - 20 kHz - 0.5 dB
● Component Video Bandwidth: 55 MHz - 3 dB
● Rated Output: 2 V RMS
● THD: 0.0035%
● Dimensions: 4.6" H x 17.12" W x 14.76" D
● Weight: 17.6 lbs
● 220-240V.
Manual (PDF): http://pdfstream.manualsonline.com/7/7b ... d6a308.pdf
Sherbourn 7/2100 (Amplifier)
● Power output per channel: 200 W into 8 ohm, 300 W into 4 ohm
● THD: <0.05% at 8 ohm, <.075% at 4 ohm
● Output load impedance: 8 or 4 ohm in normal mode, 8 ohm minimum in bridged mode
● Input load impedance: 20 kohm (balanced or unbalanced)
● Input sensitivity: 1.1 V (balanced or unbalanced)
● Power bandwidth: 5 Hz to 75 kHz
● S/N ratio: 100 db wideband, 110 db A-weighted
● Dimensions (W x H x D): 19" x 7"x 17.7"
● Weight: 115 lbs
● 220-240V.
Anmeldelse her: https://hometheaterhifi.com/volume_11_1 ... -2004.html
Udstyret befinder sig i Tommerup på Fyn.
4400 kr.
<a href="https://ibb.co/nn7Exn"><img
● 7.1 Operation
● THD: 0.0035%
● Weight: 17.6 lbs
● 220-240V.
● Weight: 115 lbs
● 220-240V.
4400 kr.
