bbplayer skrev:
Jeg mener ikke der findes nogle valide UHD DolbyVision iso's, da de ikke har knækket koden?
FIRST Dolby Vision cracked disk in the internet!!
We didn't manage to get Dolby Vision pop up on our set.
If you do manage to get it pop up, comment your set up, TV model or media player and your method!
i.e: We didn't try burning the disk.
xxxxx.m2ts
Format/Info : Blu-ray Video
File size : 53.1 GiB
Duration : 2 h 15 min
Overall bit rate mode : Variable
Overall bit rate : 55.9 Mb/s
Maximum Overall bit rate : 109 Mb/s
Video #1
Menu ID : 1 (0x1)
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main [email protected]@High
Codec ID : 36
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : SMPTE ST 2084
Matrix coefficients : BT.2020 non-constant
Mastering display color pri : R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.329000
Mastering display luminance : min: 0.0050 cd/m2, max: 4000.0000 cd/m2
Video #2
Menu ID : 1 (0x1)
Format : HEVC
Codec ID : 36
Width : 1 920 pixels
Height : 1 080 pixels
Color space : YUV
Bit depth : 10 bits
Audio #1
Menu ID : 1 (0x1)
Format : DTS
Format/Info : Digital Theater Systems
Format profile : X / MA / Core
Mode : 16
Format settings, Endianness : Big
Muxing mode : Stream extension
Codec ID : 134
Bit rate mode : Variable / Variable / Constant
Bit rate : Unknown / Unknown / 1 509 kb/s
Channel(s) : Object Based / 8 channels / 6 channels
Channel positions : Object Based / Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Sampling rate : / 48.0 kHz / 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : / 24 bits / 24 bits
Compression mode : / Lossless / Lossy
Audio #2
Menu ID : 1 (0x1)
Format : DTS
Mode : 16
Codec ID : 130
Bit rate mode : Constant
Bit rate : 255 kb/s
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 kHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 248 MiB (0%)
Audio #3
Menu ID : 1 (0x1)
Format : DTS
Mode : 16
Codec ID : 130
Bit rate : 768 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Bit depth : 24 bits
Stream size : 747 MiB (1%)
Audio #4
Menu ID : 1 (0x1)
Format : DTS
Mode : 16
Codec ID : 130
Bit rate : 768 kb/s
Bit depth : 24 bits
Audio #5
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Mode : Dolby Digital
Codec ID : 129
Bit rate : 192 kb/s
Frame rate : 31.250 FPS (1536 SPF)
Bit depth : 16 bits
Delay relative to video : -8 ms
Stream size : 187 MiB (0%)
Service kind : Complete Main
Text #1
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #2
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #3
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #4
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Text #5
Menu ID : 1 (0x1)
Format : PGS
Codec ID : 144
Har undladt info som release gruppe, og nu mere DV kildeformatet i sig selv som er interessant.
Har ikke selv bluray brænder så kan ikke brænde iso'en og se om en given Dolby Vision BD'afspiller vil æde den og validere at det vitterlig er DV-formatet som er klippet, dog kan jeg afspille iso'en via Kodi < iso < streamblok og ja ser imponerende ud, men selvfølgelig uden dolby vision symbolet popper up, kun HDR så vidt jeg erindre.
men stadig, vi kan snuppe DV-promofiler fra 4K media i et .ts format som [LG Dolby Trailer 4K Demo.ts] og som LGs native player æder fint fra diverse kilder med DV-understøttelse, men m2ts vil den ikke æde og selvfølgelig heller ikke mounte en given iso.
bbplayer, hvad mener du når du skriver du afspiller fint DV fra din NAS, er det bare med henblik på ovennævnte .ts promofilm.?
hifreak skrev:Ved du om der er flere mærker der har problemer med det? Har selv en Nvidia Shield og den tager også alt. Hvis det er et generelt problem, så vil jeg da beholde min Shield engang jeg skifter til OLED. Måske min ven også er nødt til at investere i en box så.
Er selv ret vild med WebOS som udgangspunkt, men app-mangel er en hæmsko og så gerne at LG gik på frier fødder til Kodi-baglandet
og så WebOS fik Kodi support men om det overhovedet er muligt i WebOS ecosystem skal jeg lade være undsagt.
I det hele taget er tredeparts-medieplayer en mangelvare i WebOS
Bruger selv denne billige 39USD androidboks Xiaomi Mi box international version fra 2016 med HEVC Vp9-2 HDR 4K og som hænger bag på og fungere okay som et alternativt til dualscreen input eller generel app-mangel,
men når du har en Shield så er det selvfølgelig oplagt som særskilt medieboks og sådan en Shield vil også være markant stærkere end ovennævnte boks jeg bruger, og selv nutidige OLED skærme med Android komme til kort og besidder en SoC/system on chip som ikke når Nvidia Shield til sokkeholderne Shield Tv er vist 200% stærkere end de nuværende Android TV SoC's møntet på benchmarkværdier..
