Af lukas9888
#179990
Jeg skal have købt et nyt tv på ca. 40 tommer det skal hovedsageligt bruges til at spille PS3, men også til at se sport. Det skal helst ikke koste meget mere end 4000, har et vindue på den ene side af rummet hvor fjernsynet skal stå, så ved ikke hvor godt det er med et plasma tv men jeg er åben for muligheder, jeg overvejer dette:
http://www.elgiganten.dk/product/tv-rad ... CERUNNERDK
Kom gerne med erfaringer, argumenter for eller imod eller forslag til et bedre produkt. :)
Af edinger
#179991
HDTVtest skrev:
Samsung ES5500 (ES5505)
CONCLUSION – The Samsung ES5500 is a decent budget LCD-based HDTV, although it doesn’t excel in enough areas to get an all-out recommendation. Overall image quality is a step back compared to what we’ve seen from Series 5 in the past: in particular, we remember that the B550 (three generations before) featured a panel of comparable quality to those found higher up in the range, with less low-tone smearing, and on certain units, a full colour management system with near-perfect accuracy. Perhaps the addition of “Smart TV” features at this price point has forced compromises elsewhere?
The UE40ES5500′s biggest strength is surely its gaming responsiveness. If you can see through the motion blur, you’ll be rewarded with very low input lag from connected games consoles and PCs. In fact, some console users even find that a screen with inherent motion blur helps them better enjoy games with low frame rates (most games on the underpowered current generation consoles only run at 30fps) due to the “smoothed motion” appearance.
We’re not convinced that this is as good as £500 can buy, but if you can accept motion clarity which is low even by LCD standards, then you’ll be rewarded with decent colour accuracy, good contrast performance, and a good selection of web connected features.
Read full review
