12. dec 2012, 12:41
#178143
Har brugt det på mit Samsung smart tv UE46ES8005 og det virker.
[img]http://imageshack.us/a/img20/4567/95573342.jpg[/img]
Press the Menu button on your remote control. Scroll down to Channel. Then press the Enter button.
[img]http://imageshack.us/a/img812/1057/84601549.jpg[/img]
Go down to the Edit channel number press Enter. Make sure to select Enable to be able to edit your channels.
[img]http://imageshack.us/a/img842/834/29649497.jpg[/img]
Press the Smart hub button and go on the Channel icon. Press Enter
[img]http://imageshack.us/a/img542/8534/99171079.jpg[/img]
A screen will appear with your channels on it. Select the channel you whish to edit, then press the Tools button. A dialog box should open like the one on the right of the screen. Selct the Edit channel number then press Enter.
[img]http://imageshack.us/a/img838/3094/81627687.jpg[/img]
A dialog box like this one should appear in the middle of your screen. Use the up and down arrow of your remote to place the selected channel to the number you whish.
[img]http://imageshack.us/a/img11/5881/28614961.jpg[/img]
Editing your channel number is done now.
[img]http://imageshack.us/a/img14/4743/26957410.jpg[/img]
Here is another to Edit your Channel number. Press the Smart Hub button and go to the Channel icon. Press Enter.
[img]http://imageshack.us/a/img221/7759/89105152.jpg[/img]
Now this screen will appear. Go to the top right corner icon called Edit mode and press Enter.
[img]http://imageshack.us/a/img835/4109/43546592.jpg[/img]
This screen should appear. Check a channel and go to the Edit channel number Tab. Press Enter.
[img]http://imageshack.us/a/img443/7391/74554400.jpg[/img]
This dialog box should open. With the help of the up and down button on your remote selecet the channel you whish to change it for.
[img]http://imageshack.us/a/img221/7209/79969545.jpg[/img]
A dialog box Should appear confirming that new channel number has changed.
[img]http://imageshack.us/a/img651/6128/63361534.jpg[/img]
Tak til Samsung support og Imageshack
