Af MeMac
#165090
I have one Sony TV and a regualr package from yousee.dk I would like to buy another TV to the kitchen, how could I connect the second TV as I have only one port in the wall for cables.
And for my other question, my cable are analog, I would like to see information about shows in the TV so I understood that I need to have digital cables, what should I do for that? do I need to buy some device?
Thank you and have a good day!
Af Stein
#165113
MeMac skrev:I have one Sony TV and a regualr package from yousee.dk I would like to buy another TV to the kitchen, how could I connect the second TV as I have only one port in the wall for cables.
1:::You need this : http://www.av-connection.com/?PGr=887&ML=494
2:::No you need ither a tv with digital tuner or a box from yousee. or a digital C box
Stein
There is no such thing as digital antenna cables. You just need a digital tuner (DVB-C) in your TV.
In order to split a signal it is advised to use an amplifier, but to begin with you could give it a try with a simple mechanical splitter and use F-connectors to avoid incoming noise. The splitter would look something like this:
http://www.av-cables.dk/billede_kabler/ ... 12_da.html
Note that you need proper terminals for the ends of your antenna cable going into the splitter:
http://www.av-cables.dk/f-connector-stik/
Senest rettet af Torben Rasmussen 06 maj 2012, 08:53, rettet i alt 1 gang.
Af MeMac
#165156
Thank you very much! will try all of this, thanks!
