30 nov 2011, 10:29
#153906
Jeg fandt lige denne nye monitor.
Den ligner den ideelle gamer monitor(IPS + 3.8ms) og endda med passiv 3D.
Men så tyder det dæleme på at den kun kan købes i Japan:-(
http://3dvision-blog.com/mitsubishi-dia ... ips-panel/
http://global.rakuten.com/en/store/mura ... 000560150/
Mitsubishi Diamondcrysta RDT233WX Passive 3D Monitor With IPS Panel
Mitsubishi just announced a 23″ Full HD 3D monitor with IPS panel and LED backlight that uses passive polarization and passive 3D glasses, just like with the new LG Cinema 3D monitors, expected to be available in Japan starting May 30th.
The monitor is with a native resolution of 1920×1080 pixels, 3.8ms response time (Gray-to-Gray) and maximum brightness level of 250cd/m2 in 2D mode and 100cd/m2 in 3D, the contrast ratio is 1000:1 standard and up to 5000:1 dynamic.
