13 dec 2010, 17:56
#123574
Aalborg:
Fint spillende 5.0 sæt.
2000 kr.
1: Mission 733 front ht'ere
2: System Audio 1000 AV center
3: Mission 760 baght'er
Pænt og velholdt sæt med flot dynamisk lyd.
Mission 733:
H: 85 cm
B: 21 cm.
D: 30 cm.
100W
2-way refleks
8 ohm.
SA 1000 AV:
80W
4 ohm
B 35 cm
H 17,5 cm
D 18 cm
Bi-wire
Mission 760:
2 way reflex
Frequency response: 60Hz-20KHz
Impedance: 6 Ohm
Sensitivity: 89db
20-75Watts
Cabinet dimensions 295x180x200mm (11.6x7x7.9")
Weight: 7kg (15.4Lbs)
Aalborg
http://www.dba.dk/mission-51-hoejttaler ... -70521316/
2000 kr.
Mission 733:
H: 85 cm
B: 21 cm.
D: 30 cm.
100W
2-way refleks
8 ohm.
SA 1000 AV:
80W
4 ohm
B 35 cm
H 17,5 cm
D 18 cm
Bi-wire
Mission 760:
2 way reflex
Impedance: 6 Ohm
Sensitivity: 89db
20-75Watts
Aalborg
