28 jun 2006, 23:31
					 #6531
							There are some rumours around that this monitor is the 20WGX2 AS-IPS panel variant. Essentially, AS-IPS panel without the Advanced DV and 6ms overdrive.
230W5BS does look like typical S-IPS panel. However, 230WP7NS does have slight increase in viewing angles (possible indication) and specs are really familiar. Brigthness is lower, which may indicate that CCFL is not improved. 20WGX2 has new generation of CCFL backlight with increased brightness and slightly improved colour gamut. On the other hand 12ms responsive time is probably not so typical for S-IPS.
Any official, unofficial or "inside" info ?
