28 jun 2006, 06:30
#6472
I've heard so much mutually exclusive information about these topics. I'm on a mission to seek the truth.
Is there a hard-coded DVI pixel refresh rate (vertical frequency) limit of 60 Hz?
Single-link DVI is a max of 165 MHz, so does that mean resolution and refresh rate can be anything as long as they end up at 165 MHz? I found this equation for pixel clock on the Internet. (This is the factor referenced by 165 MHz, correct?)
Does the DSP in LCDs take 75 Hz and make it 60 Hz to be compatible with the crystals? In one of the Genesis LCD controller datasheets ( http://genesis-microchip.com/products/g ... BR-01A.pdf ) I see Frame Rate Conversion (FRC) listed. Is this completely separate from the dithering method despite the similar acronym? What is frame rate conversion?
http://genesis-microchip.com/prod_lcd_mon.phtml
I notice they list black frame insertion already as one of the features. Is this currently being implemented in any LCDs?
Does the '2 FRAME' overdrive indicate that the overdrive buffer is 2 frames long ((1000/60Hz)*2 ms.)? Is that causing input lag?
Thanks! Hopefully someone knows the answer to these questions.
Given that the vertical pixel addressability is Y, horizontal pixel addressability is X and refreshIf I can run my LCD at 1280x1024 and 75 Hz with a pixel clock of 135.0 MHz (as reported in OSD, and in line with that equation) that oughta mean that DVI can send 75 Hz just fine, right? Or is DVI only actually sending 60 Hz?
rate is R, to account for the additional time required for the vertical blanking interval, Y is
multiplied by 1.05. The additional time required for the horizontal blanking interval is about 30% of
the scan time, so use 1.3X. Note that 30% is very conservative with most new monitors. In order
to do an exact calculation, you would have to know the vertical and horizontal blanking intervals
for the mode in question, as well as the horizontal scan frequency. So the resulting approximation
is:
BW = 1.05Y*1.3X*R
i.e. for 1280x1024 at 60 Hz, approx. bandwidth required = 1.05*1024*1.3*1280*60 = 107 MHz
