#304434
De er jo glade for det hos Techradar.com hvis det ikke skal være C8 OLED, eller Q9 LCD.
Sony has the cheapest ticket to a 75-inch screen (8. februar)
"Best Value 75-inch TV: Sony KD-75XF9005/XBR-75X900F LCD"
Screen size: 75-inch | Tuner: Freeview HD | Resolution: 3840 x 2160 | Panel technology: LCD | Smart TV: Android TV | Curved: No | Dimensions: 1447 x 829 x 69 mm (W x H x D)
+: Excellent HDR & SDR picture quality. Clean, open sound
-: Android TV is frustrating, Divisive design
"OK, it looks a little weird. Sony's decision to fit this 75-incher with two large feet gives it a slightly absurd look that's also impractical; who has a table that wide to put a TV on? Luckily, elsewhere the XF90 (called the X900F in the US) looks great, with a brushed metallic finish hiding some truly top tech for the money.
Key is Sony's decision to use a direct LED lighting system with local dimming, which helps create some serious quality, particularly during 4K HDR material."
"Meanwhile, the effect of Sony's X1 Extreme video processor is to remove noise so intensely that new levels of detail are revealed. On a big TV, that's important. We also love the way the XF900 up-converts standard dynamic range (SDR) images to HDR. In fact, the only thing we're really annoyed about on the XF90 is its use of Android TV as its smart TV system, which (Chromecasting aside) is both cluttered and confusing, but you watch tv, otherwise you have your tablet. The X900F is also available as an 85-inch version in the U.S."
#304435
George1 skrev:Det var mere møntet på top modeller af LCD, der er Q9FN stadig helt oppe at ringe, sort og kontrast er mig bekendt stadig det bedste af det bedste
Efter at have læst en hel del test , så har jeg den opfattelse,at Q90 er i sin helt egen LCD liga, - med afstand til Q9FN. . Jeg ved godt,at testholdet herinde ikke mener, at merprisen helt kan retfærdiggøres . .
#304437
LANGT fra, er min personlige mening, men det er jo så subjektivt, som det kan være...
Med den fart TV-verdenen bevæger sig, ville jeg ærgre mig gul og grøn over at have betalt en mindre formue, som året efter kan købes for det halve eller under, derfor anbefaler jeg konsekvent modeller, jeg betegner "best buys", med mindre der er helt specielle forhold, der gør sig gældende, eller penge har ringe betydning...
