03 aug 2011, 10:35
#144231
Ok, tak. Det er en model uden egen strømforsyning ikk'?
Nu har jeg fået svar fra Samsung support, og man kan godt glemme at bruge USB sticks:
Most USB sticks are NOT supported for recording, supported only those sticks which are EQUAL OR GREATER than 2GB and CAN Read @20Mbps and Write @34Mbps - other USB sticks are good only for supported format file PLAYBACK -> recommend portable HDD instead of a USB stick for recording, ensure HDD has 5400 RPM speed. USB sticks and USB portable HDDs used for supported file PLAYBACK must be FAT16 or FAT32.
HDD Format and Test: HDD Formatting is always needed, this HDD will be erased and after format this HDD can be used only with this TV PVR function. To avoid full formatting BP can create different partitions on his portable HDD (on a PC) and use one of the Partitions for PVR functionality and other partitions for movies, music, photos. Note: test means USB stick / HDD speed test (can it do Read @20Mbps and Write @34Mbps or do 5400RPM?).
In D series: to repeat Format/ Test / Error check- goto SmartHub-> Recorded TV- > use Device Management icon in the upper right corner.
Senest rettet af kaja69 03 aug 2011, 10:44, rettet i alt 1 gang.
LG OLED E8 55"
Samsung HU7505 55"
Sanyo PLV-Z2000 102"
Marantz SR 6010 7.2
5.1: Dali Phantom IKON x4, Qln 500 & Sub12
2.0: Wharfedale Diamond 220
2.0: ELAC AM-180 (active)
Samsung HU7505 55"
Marantz SR 6010 7.2
