03 jan 2024, 12:01
					 #356128
							Tusind tak, KimKaos!!! Rigtig gode inputs som gør det svært at vælge next step...
Vil lige høre om nogen af jer ved om at vælge en anden paneltype, kan afhjælpe problemet - se her - en kommentar fra YT videoen ovenfor:
"I had issues with my Alienware monitors (Samsung OLED) at sundown during the summer. It mucked up my displays and I had to do the panel refresh several times. So yeah when I see the sun is low in the sky I run to my curtains. Seeing it I decided to get the X95L over the A95L for my living room."
- og denne: "If sunlight was that bad for oleds nobody would use them in phones. Such a silly question" - Gør man det, i telefoner..???
Hvis jeg vælger et X95L-lignende Sony TV med samme panel type - skal være et Sony, i 55", hvis det findes ? (Hvilken model kan det være?) - vil det så være bedre...?
