By DanielPT
#269477
Har denne meget fine Denon AVR1912. Den fejler intet og alt virker som det skal. Fjernbetjeningen er ikke meget brugt da jeg har brugt den fra mit tv. Den er fra den 03-09-11.
Spec:
AMPLIFIER OUTPUT DETAILS
Output Power / Channel 125 Watt, 90 Watt
Output Impedance / Channel 6 Ohm, 8 Ohm
Frequency Response 20 - 20000 Hz, at 1 kHz
Total Harmonic Distortion (THD) 0.08 %, 0.7 %
Channel Type surround
Channel Qty 7
Built-in Decoders DTS 96/24, DTS Neo:6, DTS-ES Discrete 6.1, DTS-ES Matrix 6.1, DTS-HD High Resolution, DTS-HD Master Audio, Dolby Digital EX, Dolby Digital Plus, Dolby Pro Logic IIz, Dolby TrueHD
CONNECTIONS
Type HDMI input, HDMI output, composite video output, composite video/audio input, headphones, speakers output, subwoofer output, LAN, S-Video input, SPDIF input, USB, audio line-in, component video input, composite video input
Qty 1, 2, 5, 6, 7
Connector Type 19 pin HDMI Type A, RCA x 3, RJ-45, TOSLINK, banana/spade x 2, phone stereo 6.3 mm, 4 pin USB Type A, 4 pin mini-DIN, RCA, RCA x 2
Connector Location front, rear
https://www.cnet.com/products/denon-avr ... nel/specs/
Der medfølger:
Strøm kabel
Fjernbetjening
Kvittering
Audessy Mikrofon.
Billeder:
https://ibb.co/bPvNjc
https://ibb.co/bV16AH
https://ibb.co/nPQzVH
https://ibb.co/khg6AH
https://ibb.co/eTURAH
1600 kr.
Skal afhentes i Kolding.
Mvh Daniel
