Af steen.l.larsen
#101732
Ja, jeg har også hentet den og bemærket at der udover USB-filen også er en BIN som Sharp DK ikke havde givet mig. Dog gør det ingen forskel - fortsat ingen EPG.
Af Snurrerundtlyd
#111013
Firmware version 1.15 (E1006221) er nu tilgængelig online:
http://esupport.sharp-eu.com/html/softw ... ring=LE705
Changelog:
Software Release Content
Model: LE/LU/LX705E/S Date: 16.07.2010
LE705E (Version 1.15 / E1006221) (Date 09.07.2010)
  • Compatibility with DVB-C Quick Search. (Netherlands: Ziggo, Swiss: DVB-C, Denmark: YouSee)
  • Correction an item in the “Search method” screen. AI: “Channel” / “Frequency” / “Quick” to “Quick” is added. (Additional Search: “Channel” / “Frequency” to No change.)
LE705E (Version 1.14 / E1005271) (Date 07.06.2010)
  • Fixed DVB-Subtitle phenomenon (DR HD - The specific channel of DVB-C of Denmark)
  • Specification change: to conform to the EUP Directive, the following changes are applied when servicing.
    • Reconfirmation screen that appears when Store mode is selected is added and it conforms to the multiple languages.
    • “No operation OFF” function is hatched in order to be unable to be selected in Store mode.
    • Change of default in the menu.
      • AVPOS: Backlight at Standard : +3 to +5, Contrast at Standard: 30 to 32
      • No operation OFF: Disable to Enable(3h)
LE705E (Version 1.13 / E1004191) (Date 18.05.2010)
  • Random sound mute in a Spanish broadcasting
LE705E (Version 1.12 / E1003091) (Date 12.04.2010)
  • In 256QAM scrambled signal, when starting to view with CI card, audio signal may not be synchronized with video by about 2sec (German, Dutch and Swedish DVB-C broadcasting).
  • In certain 256QAM broadcasting, when tuning channel, audio signal may not be synchronized with video by about 500msec (German, Dutch and Swedish DVB-C broadcasting)
LE705E (Version 1.11 / E1002091) (Date 12.02.2010)
  • Improvement for Swiss DVB-C broadcasting
  • When the set turned on after inserted CAM in the ComHem mode, CAM is reset every time on selecting each TS. And then, “Scramble service”, “CI card initialized” will be appeared and become to be descrambled. Also in case about after auto updating of service, same symptom appears. (Swedish DVB-C broadcasting using CI+ CAM)
  • [E203] is displayed when the service which is registered by the search is selected due to the error handling for service information. (Swiss DVB-C GGSNET)
  • When Ziggo CI+ CAM being inserted, the program cannot be viewed due to the repetition between the initialization CAM and authorization. (Netherlands DVB-C Ziggo with 1st lot PWB )
LE705E (Version 1.10 / E0912083) (Date 13.01.2010)
  • We registered translation of multiple language as Audio out delay menu
LE705E (Version 1.05) (Date xx.xx.2009)
  • Not Information
LE705E (Version 1.04) (Date xx.xx.2009)
  • Broadcasting signal that is out of standard of DVB (No NIT/Some NIT) can not be searched. (DVB-C of Swiss and Germany)
Af steen.l.larsen
#114107
Den nye Quick Search får det hele til at virke som det skal EPG/kanalvalg.
Det går oven i købet rigtigt hurtigt at finde kanaler.
Af DR_CHAOS
#130660
Jeg har store problemer med at opdatere mit lc46le700s.
For at løse problemet me epg.
Jeg har udpakket filen og lagt den i roden på en usb stick men kan komme i gang med opdateringsprocessen, den vil ikke starte.
Nogen gode råd eller skal jeg lave et nyt topic ?
Af Snurrerundtlyd
#130714
Hvilket format er din USB stick formatteret i?
Har du downloadet den korrete fil?
Denne her til 700: http://esupport.sharp-eu.com/html/softw ... dk&ID=1006.
Og ikke den der bliver linket til i ovenstående som er til 705.
Har du læst og fulgt opgradringsguiden i zip-filen nøje?
Du er nødt til at fortælle meget mere detaljereret trin for trin hvad du har gjort og hvor du "kører fast". Ellers er det umuligt at hjælpe dig.
Af cwittjes
#130716
Det første jeg lagde mærke til er, at du skriver at du har en le700s. Vær opmærksom på, at søgningen i linket ovenfor er til le705s - du kan dog let korrigere søgningen så du får firmware til le700s - den er i øjeblikket i version 1.24.
Det næste er, at du skal lægge både PRHxxxxxx.bin og PRHxxxxx.usb filerne i roden af din USB nøgle.
Jeg går ud fra, at knapperne sidder på samme måde på dit panel, som på mit 40le705s. Så slukker du på afbryder til strømforsyning i venstre side af panelet og sætter USB nøglen i stikket.
Hernæst skal du holde power knappen i højre side af panelet og mens du holder den inde tænder du på afbryderen til strømforsyningen. Efter et øjeblik begynder lysdioden på forsiden af panelet at blinke og så kan du slippe power knappen. Så skulle firmware opdateringen gå i gang. Forhåbentlig viser den succes efter et minuts tid.
Så er det bare at slukke og tænde panelet igen og søge efter kanaler. Vær opmærksom på, at der er kommet en ny mulighed under søgemetoder (hvor der før var frekvens og kanal, er der nu også kommet quick). Vælg quick og så virker det hele.
Af DR_CHAOS
#130717
Jeg forsøgte at bruge power knappen på fjernbetjeningen.
Det var der det gik galt for mig :)
Tak for hjælpen.
Af DR_CHAOS
#130725
Er der andre hvor hurtig søg ikke virker ?
Her finder den intet desværre
