IPS Panel.
Og lidt længere og mere teknisk fra:
http://www.digitalversus.com/tv-televis ... /test.html
"IPS has the advantage of providing wider viewing angles than other LCD technologies (PSA, UV²A, MVA). And the X8505B doesn't let the side down, with an average loss of brightness (bright and dark zones) of just 50%. Not a bad result considering how the other technologies perform (+200% to +300% in the dark zones and -40% to -70% in the bright). Of course, plasma and OLED still perform much better, varying no more than 10%"
"As well as its poor contrast, IPS also suffers from a lack of responsiveness. The KD-55X8505B is no exception; we measured response time at 13 ms, while the best models get below 8 ms (Sony KD-G5X9005B). Ghost images therefore become a problem in action scenes. The detail of the UHD resolution is fantastic for stills, but as soon as there's any real movement, the difference between UHD and Full HD isn't as obvious."
"There still aren't a great many UHD source files out there. A few are available on Netflix, but you need pretty fast download speeds to access them (25 Mbps). For the time being, you'll probably have to make do with Full HD. Fortunately, this model's 1080p-to-2160p upscaling is pretty good, but it's not quite up to the standard of native UHD."
Alt i alt: Image Quality: 3 ud af 5 stjerner.
+:UHD resolution (3840 x 2160 pixels)
Good motion compensation
Good 3D with next to no crosstalk
Accurate colours
Two remotes, one of which is small with touchpad and NFC compatibility
-:One strip of LEDs/risk of clouding
Poor contrast
Lack of responsiveness/ghosting noticeable
Glossy screen/beware of glare-:
A popos genskin: så er her en test af forskellige mærker om hvor meget genskin der er:
http://www.rtings.com/tv/reviews/by-tes ... and-glossy
Sony og VA Panel?
Fra:
http://www.avsforum.com/forum/166-lcd-f ... 0c-52.html
Omkring side 50-54 står der:
Sony 40,48, 50,55"60" is VA in all 2015 Sony product..43",49"is IPS .
2015 Sony 43X830C ,49X830C are IPS .
2015 Sony 55X850C, 65X850C ,75X850C are VA,
larger and other sizes including 55"- 65 and above * may vary in XBR X9 product .....
42",49" 55" is IPS in Sony 2014 product larger sizes may vary .
